Quick question
Old Apr 21, 2004 | 08:13 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Quick question
I tried posting this in the Transmission section, but no one would reply to me...
My TH700R4 automatic tranny is starting to show its age.
My car just rolled 150K miles and the tranny has been shifting harder. A friend of mine mentioned that I may need to replace the Transmission Modulator. I don't know alot about transmissions, so my question is...
Does my transmission have a transmission modulator? If not, is there anything I can do to help my tranny's shifting?
Any info/advice would be greatly appreciated.
Thank you.
Old Apr 21, 2004 | 06:50 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Tras modulaters are vacuum conrolled. Our cars use a throttle valve. It is controlled by vacuum. Hard shifting could be caused by a cable out of adjustment. What does the fluid look like?
Old Apr 22, 2004 | 07:59 AM
As far as I know, the fluid looks normal.
I did drop the tranny pan (last summer) and changed the filter & fluid.
Old Apr 22, 2004 | 08:01 AM
ede's Avatar
ede
no modulator on the 700r4. try adjusting the tv cable and make sure the tv is working. might want to take it to a trans shop and let them check it over.
Old Apr 22, 2004 | 06:59 PM
dankhound's Avatar
Car: 91 RS
Hehe just look at my post and some things are a litlle out of place
trans modulater-vacuum controlled-mostly on older vehicles
throttle vavle-cable operated-what we have on our cars
The fluid shouldnt be black and it shouldnt smell burnt but if its thats new its probably alright. Tv cable is probably out of adjustment.
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
