2.77-->3.27...Help with speedo gears??
Old Apr 21, 2004 | 12:51 PM
DoBeR's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Transmission: 4 Spd Auto
Has anyone done this swap before?? I want to make sure I have the right driven and drive gears before I actually swap them out for my old ones. I called the dealership and got the parts and they gave me a red drive gear and a green driven gear.
How do I know if these will give me the correct ratio???
Old Apr 22, 2004 | 01:36 PM
DoBeR's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Does anyone know the correct ratio of gears to fix the speedo??
Old Apr 23, 2004 | 02:53 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
When I pulled my 3.27, I thought it was the red gear and gray gear, but I'm not sure. I'll have to go home and look to be sure.
Old Jun 23, 2004 | 01:24 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
I did the exact same swap and also need to know ASAP....
Old Jun 24, 2004 | 09:41 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
www.700r4.com if you have an auto, I don't know what to tell the manual guys. Just click the links to get you to the speedo gear calculator here:
http://www.700r4.com/speedoCalc/speedocalc.shtml
It tells me for a 245/50-16 tire you need the 17 tooth drive and 43 tooth driven gears. I'll be doing the same swap soon.
Ed
Old Jun 24, 2004 | 10:23 PM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
I did the same swap (2.73 -> 3.23) on an electronic speedo (92 camaro) and NOBODY could get it right.
700R4.com sent me the wrong gears and when i called them back they said they dont have what i want
My uncle owns a transmission shop and he couldn't even locate what I needed.
Now I plan on getting the unit from Dakota Digital that modifies the electrical signal to the speedo and/or computer. That way it's easier to change if you get tired of 3.23s and go higher.
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
88rscamar0
Sep 23, 2015 09:08 PM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
