Rear Spacer for a 7.5
Car: 87 plane jane with gfx
Engine: 350 worked vortec head .515 .515 cam and 1.6 rockers and shorties for now til i can afford the supercomps
Transmission: super t-10 or t-5
Axle/Gears: auburn with 3.42 stock axles
does anyone know of a company that makes a ring gear spacer for a 7.5 i just put 410s in my rear. i thought it would be fine but i found out after i put the gears in they where for a series 3 carrier and not the series 2 carrier if anyone knows a company that makes please let me know because summit or jegs doesnt sell the part and i have found one place that does but i'm looking for the cheapest one.or if anyone has a used one with the bolts let me know
thanks
-steve
thanks
-steve
Car: 4
Engine: 6
Transmission: 5
the cheapest one
Do you really want that (the cheapest thing you can find regardles of all else), or do you want one that will work for sure and cause you no trouble? Considering how expensive gears and carriers and setup labor and down time and all that can be, what's the difference between a $65 spacer and a $75 spacer, or whatever, if that's what it takes to guarantee a successful job?
http://www.drivetrainspecialists.com...=28&cat=GM+7.5 Do a search on that page for the word "spacer", you'll find the one you're looking for about 2/3 of the way down the page.
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
yep have to agree there you shouldnt be thinking of the cheapest when it comes to parts of your car that are going to make it driveable or reliable .....you should be thinking of quality ...i uderstand that most expensive doesnt always make it better either lol but thats usually what you find when your workin on your car ...
well the setup labor and every thing is done for free i got the gears for free and i got a descent spacer i think to it's from gm so hopefully it will hold up the way i want it to.
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
kah992
Aug 19, 2015 02:55 PM
