which rear gears with my tranny combo?
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
i'm running about 350HP maybe more through an 1800 stall (soon to be a 2400) in a turbo 400. I currently have 3.23 LSD in the back. my launches suck and my 1/4 times are suffering. I'm planning on swapping out the 3.23's for either a set of 3.55's or 3.73's.
I'm more leaning towards the 3.73's but i'm getting alot of flack from a few friends who think i should use 3.55's instead because of the low gearing of first gear in the TH400...
What do you guys think? I'm looking for best launch/ 1/4 times and maybe the ability to pull the front off the concrete a little.... it'll expand the suspention right now if i launch at 4K rpm but i wanna shock the riceboys with a nice jump in the front
thanks for any info...
Dave
Dave
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
A TH400 has a 2.48 first gear vs. s 700R4's 3.06 first. That's higher, not lower. You would need a 3.73 with your TH400 to equal the launch ratio of a 700R4/3.08 combo. You would need a 4.56 rear ratio with your TH400 to equal the launch ratio of a 700R4/3.73 combo.
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
You drive it around much, or is it mostly a track car? 65 mph oh the I-state is gonna drive you crazy. its right about 3000 or 3200 RPM if I remember correctly. Buddy is running a 400 w/ 3.73s and won't take it on the interstate anymore. Of course he is running low 11s/ high 10s w/ a lt1 355 and a procharger...
Engine: 450HP 355
Transmission: TH350
thanks for the info...
it's more of a saturday night special / drag car than an every day driver. i still take it to work once in a while just for the hell of it.
Thanks, looks like i'll be going with what i was thinkin all along, 3.73's for me.
I'm well aware of the PITA to install the gears but other than shimming them to mesh right, is there anything else i should know before tearing into the pumpkin ?
Dave
Dave
hectre13
Dec 11, 2023 08:14 AM
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
