Sumone help me out here??
Old Apr 28, 2004 | 07:51 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
Ok, so i got the new motor about to be put in with my nasty new 700r4, overdrive is still the same, 3000 stall on it LS1 driveshaft, and now we were dabating on what gears should we stick in the rear end, my cuz says 4:56 should be fine in it cuz when we put 4:10 in one of my friends camaro's it was fast, but it coulda been faster with some 4:56's ...i donno...i dont wanna go crazy with gears so i max out real quick so if anyone can give me some RPM numbers and speeds i will be doing with 3:73's some 4:10's and the all crazy 4:56's...thanx in advance...alex...
Old Apr 29, 2004 | 04:46 AM
ede's Avatar
ede
i think you'd have to give us some rpm and speed numbers. where's you torque and hp peaks? what rpm you want to go through the traps at?
Old Apr 29, 2004 | 09:17 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Agreed. You don't want to top out before you hit the traps w/ the gears....
Specs please...
Old Apr 29, 2004 | 03:05 PM
Dominator's Avatar
Car: 1987 Camaro IROC Z
Engine: 400HP/ 355ci built by Enginefactory.com
Transmission: 700R4 built by Bowtie Overdrives
The first gear in the 700r4 is 3.06:1 ratio... you might have trouble with traction if you go much higher than 3.73 or 4.10
Old Apr 29, 2004 | 07:43 PM
Charged350's Avatar
Car: 87 IROC Z28
Well, the motor is makin 450 horses about the same for torque that are happy to to about 7000 rpm, i got the pill for the msd, the tranny is stock basically gear wise, cept for first, so the rest of the gearing is the same, now what would be ideal, im thinkin stick with 4:11 for now....and if i dont max out then ill do 4:56 or 4:88 hahaha...,
It doesnt have to be right up to the dot on the oney correct, i just want to get a baseline for this ....thanx guys
Camaro-King79
Aug 5, 2015 11:30 AM
Camaro-King79
Mar 12, 2013 11:03 AM
Napster134
Oct 12, 2010 06:51 PM
