some rear end questions
Old May 2, 2004 | 07:01 PM
white88formula's Avatar
Car: 2000 Chevy Tahoe
Engine: 5.3 v-8
hey everyone,
umm i came across a 10 bolt rearend that i wanna use, but when i measured it, its about 1in smaller than the stock rear, length wise i mean, would that make a huge difference or not?? just curious if i can use it...
drew
Old May 2, 2004 | 08:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Does it have a torque arm mount?
Without that, it doesn't matter what width it is; it won't work. With it, all you'd have to do is get wheels with a different offset.
However, it sounds like it's not out of a 3rd gen F car, or a 4th gen either; so it most likely won't work.
Old May 2, 2004 | 09:00 PM
Engine: 5.3 v-8
well i dont use a torque arm, i replaced it with the traction action lift bars from lakewood...but i figured out i wont be able to weld to that rear being cast iron and all, so not worth it thanks though
drew
Old May 3, 2004 | 04:27 AM
ede's Avatar
ede
the rears aren't cast iron and even if they were that doesn't make them unweldable. why or what do you want to weld to it?
Old May 3, 2004 | 06:51 PM
Engine: 5.3 v-8
sorry sometime i need to clarify myself on when i explain stuff, the rear end i wanted to use is out of a 1970 nova, with leaf spring set up, but its a inch smaller than the 3rd gen rear, but i found another rear for 30 bucks so, and i know it will work so yea, thanks tho..
drew
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
