Anyone ever get a screeching noise when the clutch is pressed in a t-56?
Old May 4, 2004 | 06:34 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I get a nasty screeching noise when I have the clutch pedal all the way to the floor, what the hell could this be? I just installed brand new t-56 hydraulics and a new clutch, pilot bearing, throw out bearing, and resurfaced the flywheel.
BTW: It shifts in and out of gear just fine, just when its all the way to the floor it screeches. Sounds like the throw out bearing. I do have all the carpet out, is there some sort of stop or does the carpet keep it from going all the way to the floor?
I touruqed everything down with a air wrench so I don't think anything is loose.
Old May 4, 2004 | 06:42 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Anyone ever get a screeching noise when the clutch is pressed in a t-56?
agreed.
Old May 4, 2004 | 06:44 PM
pasky's Avatar
I don't see how it can screech though, I left the stock retainer on there and the fork is grabbing it and the hydraulics are brand new? Any clues to what is causing it?
Old May 4, 2004 | 06:46 PM
jmd's Avatar
jmd
A dry bearing from the factory?
Old May 4, 2004 | 06:56 PM
pasky's Avatar
Nope, made sure it had plenty of lube when i got it, was still greased up. Im gonna take the spacer off tonight and make sure the clutch for is 100% on it, I also here a rattling noise so im thinking that retainer came off.
Old May 4, 2004 | 07:16 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I think you may be hitting. mine did something similar (not really a screech though). I had to cut the piviot tree down some. others made adjustable pushrods
also this was with thirdgen pedals
Old May 4, 2004 | 07:22 PM
pasky's Avatar
Thats what im using, so you think the thirdgen pedals have too much travel?
Old May 4, 2004 | 07:43 PM
pasky's Avatar
If thats the case, I mean I don't need it to go all the way to the floor, it disengages about 3/4's of the way just fine, im just used to stomping on it. But just want to make sure its just over extending rather than something went wrong.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
mfp189
Sep 27, 2015 09:25 AM
