Lockup time...
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
Lockup time...
ok, so i swapped in a carbed 350 and kept my overdrive tranny, now the 4 prong switch is gone on the emc harness, but i need a way to wire something up so i can lock up the converter in 4th on the highways and during some runs, i heard it knockes off a tehnth or two...
Anyway, i heard about the connecting the f and a terminals to make it lock up, but i dont see a way that would work, since there is no other wiring runnin tot he tranny, so how is it gonna get the signal, i donno...
But i need a way how to wire it up using the 4 prong connector wires...if u can help me out, it would be highly appreciated....
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
just tell me the colors of the wires already!!!!! i dont care about NC or not NC just tell me the firggin colors....and the the other post that was for the ALDL....thats great....EXCEPT WE ARENT RUNNING A COMPUTER!!!!! CARBED!!!!!
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
I bought a TH400 plastic termanal to replace the existing 4 prong unit in the transmission. It is just a spaid termanal. I got power and brought it through the switch on the brake pedal and hooked it up to the new spaid termanal on the tranny. Inside the tranny I had to replace the N/C switch with a N/O switch. Inside the tranny I wired the termanal to the N/O switch, from the N/O switch I went to one of the wires on the solenoid and the other solenoid wire is grounded.
I haven't driven the car yet, but I am an electrician and I have read the schematics for the system and gotten help from others on this site, I do not see a problem wiring it up this way. This will lock the TC anytime the tranny is in 4rth gear.
If you want part #s for the switch and termanal I can look them up.
The cost for them was around $13.00.
EDIT: If your SOL has only one wire it doesn't need to have a negative connected to ground (obviously)
Car: 87 IROC Z28
ok, i know that, but how will the tranny get a signal from the aldl if thereis NOOOOOO wires running to the tranny, i know there is a way to wire it up with a swich adn the orignal 4 prong connector, i know there is...
Car: 87 IROC Z28
thank you, thats what i was lookin for, so i dont need the other two or whatever wires there are in there
someone972
Aug 30, 2015 12:52 AM
Eric-86sc
Aug 24, 2015 09:01 PM
