Backlash and speedo gear question...
Old May 7, 2004 | 12:21 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I just got a set of motive 3.73s. I have heard they like a wider backlash? Or something of that nature. I heard like .11 or something. Guy installing my gears asked me what backlash the motives used and I'm not for sure.
Also which speedo gears do I need?
Old May 7, 2004 | 06:22 AM
ede's Avatar
ede
specs should of been etched on the gears or instruction sheet. WAG i'd say .008 or so would be upper limit, but i've never used motive gears.
Old May 7, 2004 | 11:40 AM
Transmission: 4l60e
I didn't get an instruction sheet.
And the gear is already mounted and torqued down to the posi unit. I took out the bolts and I couldn't get the ring gear off. Its on there good. I was searching through posts one night and I thought I remember someone saying like .011'' for motive gears. I just want to confirm it first. But if I have it setup at .008'' it would probably loosen up after being driven and work out pretty good.
Old May 7, 2004 | 03:26 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
For what it's worth the instruction sheet with my Motive 9" gears said .008-.012" backlash.
Old May 7, 2004 | 10:06 PM
Transmission: 4l60e
Thanks man. I needed to now that actually.
Old May 8, 2004 | 11:14 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Most aftermarket gear applications run from .008-.012" on backlash settings. I like to run mine when I set them up at .008-.010".
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
88rscamar0
Sep 23, 2015 09:08 PM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
