1999 WS6 6spd, what rear end do I have?
Old May 9, 2004 | 07:49 PM
NitrOmm's Avatar
Car: 1999 WS6
Engine: 5.7
Transmission: 6 spd
I just picked up a 1999 WS6 w/ 6spd. The rear end gears are shot. Can someone tell me what gears came in this car stock? 3:23, 3:73 ? or ?
I would like to go up a bit. What do you recomend and what does it intail regarding computer and speedometer requirements.
I still need to drive it daily... but like all of us.. I want it to hit hard.
Patrick
Old May 9, 2004 | 08:50 PM
MdFormula350's Avatar
i am pretty sure it would be 3.42's or less in that 10 bolt rear end stock.
3.73's are a nice choice for a 6 speed.
Old May 9, 2004 | 08:52 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
by all means i am NOT trying to drive you away from this message board but i must say that this board is primarily for 3rd generation f-bodies and so there will not be AS many experts on this board as there would be on a LS1 message board..... i went searching around on the internet and i found a website called LS1.com
in there i found a FAQ place that stated that your car will have a 3.42 rear axle ratio since your car is a 6 speed...it is posted here..... http://www.ls1.com/index_faq.html#501
they also have a message board on there so if u wanna join that one too you will be able to talk to a lot more 4th gen owners..........
i checked out jegs and here is a speedo recalibrator that i found for 94-03 GM vehicles..... http://www.jegs.com/cgi-bin/ncommerc...15&prmenbr=361
good luck and i hope you still post around here! and btw does your car have t-tops? cuz if so then i am so jealous!! i want your car!
Old May 10, 2004 | 02:36 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
After 93 the t-56 came with the 3:42's ONLY.....great car!
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
neekolzun
Aug 24, 2015 04:59 PM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
