T-5 fluid fill
Old May 12, 2004 | 03:29 PM
costill91Z's Avatar
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
Axle/Gears: 4.30 Dana 44 Rear 10 bolt front
T-5 fluid fill
Is it possible to fill the ATF where the shifter bolts up to on my 92rs T-5. I put synthetic in last july, but had to drain it when i removed the tranny to replace the clutch, and it was a PITA to use the filler/fluid level inspection hole, bc i had to use a suction gun and ended up spilling fluid all over me trying to wiggle around under the car.
thanks for the help/info/suggestions
mike
Old May 12, 2004 | 03:37 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
yes, works fine; just fill till it overflows out the normal fill hole
Old May 12, 2004 | 03:43 PM
costill91Z's Avatar
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
sweet, this will save me a lot of time and a ruined shirt and shorts.
car should be up and running soon, I should have just fixed it right away, would have saved the money on rebuilding the toyota tranny, but i did it at the recommendation of family since winter was coming, and they said the maro would be dangerous and unreliable. bs, the thing has been one of the most reliable cars ive owned.
thanks for the help
ps, should i go with an aftermarket shifter since its out, and if so, what kind is reliable, and wont destroy my synchro like the one i put on my old civic.
if i get a used alum. driveshaft, do i need to get a new tailshaft seal, the old one didn't leak. thanks
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mfp189
Sep 27, 2015 09:25 AM
HikoriYami
Sep 21, 2015 07:11 PM
