Help , i seriously need tranny help, everyone in here.
Old May 17, 2004 | 04:47 PM
nolanr0413's Avatar
Car: Trans am
i just spent 900 ****in dollars on a tranny , i was supposed to have mine rebuilt but i fried it. Ok so i get the car back friday , i drive it , it bogs and wont shift at wot at all, i revved it to 6500 and wasnt happy about that . I bring it back , it also has a clunk or something from 2-3 . SO i get it back today , hes like i adjusted it but i gotta order some heavy duty clutches, hes like i thought the ones from the b&m shift kit would be ok. SO it shifts normal, 5800 so im fine with that . It doesnt bog anymore but it seems slow from a dead stop. It sucks. It also doesnt 3-4 wot shift anymore, mind you a diff tranny , and it didnt want to 4-3 downshift at full throttle. It sucks , the list of **** goes on . Im writing it all down so i dont forget . Why the f doesnt this one 3-4 wot shift. I have 4.10 gears so its only 90. And why doesnt it 4-3 wot downshift, this blows , its like driving a car meant for gas milegae it blows.HOw come the other one shifted like this. Gimme some answers, the other tranny had 55000 on it , it was an 85 tranny and it shifted 3-4 wot and it was better, until i fried it. Im so pissed , can he get the parts outta the other one of what . i mean this really sucks, im so pissed. help guys and gals.
Old May 17, 2004 | 10:18 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Help , i seriously need tranny help, everyone in here.
Probably a cheapie stock-o tq. converter with no "extra" stall speed.
If he used an 84.5 - 87 core, yeah he could use parts from the olde one if they're not damaged. 88-up, no.
The 3-4 and 4-3 characteristics are totally normal for a non performance model valvebody.
You got what you paid for. An inexpensive, off-the-rack transmission. Was the olde one actually junk (broken case / v.b. etc.) or was he just wanting to stuff one in the car and send you down the road?
Old May 18, 2004 | 10:10 PM
nolanr0413's Avatar
Car: Trans am
the old one was shot, the pump went bad, and the converter was shot. and then the gears got welded together.
Old May 19, 2004 | 12:51 AM
proryder2's Avatar
Car: 73 chevy truck
Engine: 406 11.6 comp 2.02 heads
Transmission: stock th350
I GOTTA TRANY ILL SELL YOU. I WAS GUNNA PUT IT IN MY TRUCK BUT I PUT A BIG BLOCK IN IT AND NOW IM GUNNA GO WITH A 4L8OE. THIS IS WHAT THE GUY PUT IN 13 Vane Rotor Assembley in the pump;Hardened Pump Rings; Teflon Pump Bushing; Kevlar Band;Full 500 TV Boost Valve; and lots of Accumalator and Plate Modifications. The ULTIMATE Z-PAC , 14 New Frictions and steels for 3/4 clutches. A Master Rebuild Kit for all needed Soft Parts. Also the BEAST super Strength, super harden, sun shell with a new Cryo-Treated ,hardened sun shell gear .Yes the HIGH PERFORMANCE 29 element sprag. I also Install a Fairbanks "SUPER SERVO" for Super HARD HITTEN 1-2 Shifts and an SUPER FIRM 2-3 Shift. This also Provides Positive 3-2 Kickdown and a Quicker release on 4-3 downshift.This Servo has 35% more Apply Surface Than The Corvette Servo. Also Installed is a Newly Geared Light Sprung/Weighted Governor To hold for a higher shift point at Peak Power band. The Valve Body and Plate Have been Reworked, Drilled and polished to Implement our proprority version a Stage III Shift Kit. Both input and output shafts are hardened along with the 5 pinion roller planetary set. An Extra Deep Pan ILL SELL IT WITH A 2000 STALL CONVERTER FOR 800.00 I NEED MONEY REALLY BAD. IT HASN`T BEEN INSTALLED SINCE THE REBUILT
Attached Thumbnails Help , i seriously need tranny help, everyone in here.-picture-001.jpg
Fanatic1074
Oct 3, 2022 05:57 AM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
