Mushy Clutch Pedal w/ Graphical Illustration
Old May 19, 2004 | 09:33 AM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
I just had a SPEC stage 1 clutch setup installed in my car and I have a few questions.
The graph is a representation of how my clutch pedal feels. Don’t let it fool you because even though there is pressure (pedal resistance), it is very light.
About 1-1/2” to 2” before the firewall, the pedal feels like it just gives up just before the firewall. The clutch engagement is also within that 2” zone and it’s very abrupt.
There are no problems with gear selection, hot or cold.
The flywheel was supposedly resurfaced and now there is, what seems to be, a rotational vibration which the mechanic is crediting to the poly tranny mount and there is also a little chatter but it is soft.
My questions are...
1. What would cause the clutch pedal to have such a mushy feel?
2. What would cause such a “small window” of clutch engagement?
3. Could the clutch assembly be out of balance?
Thanks.
Scott
Attached Thumbnails Mushy Clutch Pedal w/ Graphical Illustration-mushyclutchpedal.gif
Old May 19, 2004 | 06:15 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Is that pedal pressure with your foot or your hand? Use your hand its much more sensative to pressure changes. You should have 1-2 inchs of free travel and then pretty even pressure after that.
The small window of clutch disengagement(the clutch is engaged when the pedal is up and the trans and engine are "connected") could be from a misadjusted clutch pedal.
As far as the vibration is concerned it could be caused by machining the flywheel but im not aware of any method of balancing an internally balanced flywheel.
Old May 20, 2004 | 07:32 AM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
I tried it with my hand and it still has the same effect. The last the last 2" of pedal travel just seem to give up. I've never experienced this before.
I thought hydraulic clutches were self adjusting. I don't thonk the pedal was touched but how would I adjust it anywayl?
How many times can a stock flywheel be machined?
Also, does it matter how the pressure plate is put on?
Thanks for the reply.
Scott
P.S. To kick me in the ***** even more, my brand new starter just took a crap on me.
Old May 20, 2004 | 09:54 AM
billv's Avatar
Car: 1986 T/A
Engine: 305 4bbl
Transmission: 5 speed
I think with hydraulic clutches, if the flywheel is machined, you can get shims that go between the crank and flywheel, according to how much the flywheel had taken off it. That way the throwout bearing is in the same place in relationship to the pressure plate as before. This may not have anything to do with your problem though.
Old May 20, 2004 | 11:09 AM
IronbackTA's Avatar
Car: 86 Aero TA
Engine: ZZ4
Transmission: T-56 Rear: Dana 44
You are correct, there are shims for maintaining the correct distance.
As for as vibration, I have noticed on doing clutch R&Rs, there is a paint mark on the flywheel (stock factory) that corresponds to a paint mark on the pressure plate. Even though these parts are supposed to be zero balanced they are not perfect. The problem is when the flywheel is resurfaced, the mark is removed. When doing a clutch job, I mark the fly wheel on the outside by the ring gear to keep the reference point. You can try rotating the pressure plate mounting points to see if you can smooth out the vibrations. This is done with the tranny out and the rear of the engine supported. I have done this and it has worked in several cases.
Also several companies, (Ram and Mcleod come to mind) that offer adjustable hydraulics. They are expensive though. Hope this info helps.
PS Did you install a new pilot bearing?
Old May 20, 2004 | 04:35 PM
dankhound's Avatar
Car: 91 RS
While some clutchs are completly self adjusting, some are only self compinsating. In other words they wont go out of adjustment due to clutch wear over time.
As far as machining the flywheel goes, there is not a maximum number of times one can be machined but there is a minimum thickness that must be observed when machining.
firebirdfreak87
Apr 15, 2013 03:12 PM
vorteciroc
Brakes
Oct 14, 2009 10:35 PM
vernw
Aftermarket Vendor Review
Jul 27, 2004 10:27 AM
Apeiron
Jun 24, 2004 08:04 AM
LinuxGuy
Jun 4, 2004 04:07 PM
