What to put in my new Posi
Old May 20, 2004 | 01:58 AM
IroczCamar0's Avatar
Car: 1989 Pontiac Trans AM GTA
recently my old rear end went bye bye and i got a new one its a 3.27 posi disc brakes i belive borg warner out of an 88 trans am and i need to put the oil or grease or whatever u call that stuff, it smells real bad anyway what do i need to put in and how much. i read u also need to put in a special additive cause its a posi. my old rear is like 95% out of the car and plan to put the new one in tmw any help would be great thanks.
thanks
chris
Old May 20, 2004 | 05:00 AM
ede's Avatar
ede
clutch type posi require posi additive, gm sells the only one i'll use. there is a fill plug, big rubber thing on cover of 9 bolts, 3/8npt plug with 3/8 square female drive on left side forward of axle tube on 10 bolts. fill it till it runs out the fill hole. the bottle has a fill spout, all i use is the bottle. if the rear is empty it'll take 2 or close to 2. i'd buy 3 because you'll have hard time getting all of it in from the bottle.
Old May 23, 2004 | 01:34 AM
this is the stuff i bought ...it says on the back "Compatible with limited slip friction modifiers". i assume this is all i have to put in, if not let me know
Old May 23, 2004 | 01:51 AM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Right, but you still need one (small) bottle GM posi additive, buy it at any GM dealer, they know what you want.
Old May 23, 2004 | 02:07 AM
yea i have to go the the chevy dealer tmw and get the gasket for the cover plate and i guess i pick up a small bottle of that...do i put that stuff in first? and do i use the whole bottle?
Old May 23, 2004 | 02:19 AM
Yes, put one bottle in first (it's only 4 us. fl.oz.), some guys here put in two bottles, but I'd say start with one (recommended by GM)
The part nr. for the bottle is: 1052358, Goodwrench Limited Slip Differential Lubricant Additive.
The part nr. for the gasket you need is: 12523445.
BTW, you need at least two bottles axle lubricant , you showed above!!
Good Luck!!
Old May 23, 2004 | 08:57 AM
yea i got 3 bottles of the lubricant....just in case
thanks for the info
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
mcgarnicle
Aug 12, 2015 04:58 PM
