couple quick t56 questions
Old May 22, 2004 | 06:05 PM
white88formula's Avatar
Car: 2000 Chevy Tahoe
Engine: 5.3 v-8
i got a t56 out of a 95 maro, wondering do i have to cut the hole the shifter sticks threw??? i know the aftermarket t56 is a lil longer, but this is a stock t56 and should be same length as a t5, also can i use the same bolt from the old presure plate to put the lt1 one together???
thanks
drew
Old May 23, 2004 | 08:32 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
this will answer a lot of questions...https://www.thirdgen.org/techbb2/sho...hreadid=229205
Old May 23, 2004 | 10:03 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: couple quick t56 questions
No. Since they are unique, you need the T56 PP bolts. I would recommend using a tap on the flywheel holes to chase the threads, getting new PP bolts, and using a tq. wrench. They're a kind of smallish thread and can break off so it's best to take no chances.
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
