TCC lock up questions
Old May 24, 2004 | 07:36 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Have no TCC after a tranny swap.
My friend bought a cheap camaro -88 with a non working TH700, I had my old TH700 from my ta-89 ( worked perfect least year!) just laying so we put it on his camaro and lost the TCC?
Brake switch OK
ECM engage the TCC
Ground terminal F on ALDL and the fuse for the gauges blows?
any ideas?
Will check all wiring this weekend, what could it else be?
/N.
Old May 24, 2004 | 02:15 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
another question:
Why dont TCC lock up in D? is it the shifter position?
Old May 24, 2004 | 07:44 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
I think there is a temp switch in the valve body that won't let lockup happen till trans is like 120 degrees. That could be taco'd or maybe the tcc solenoid is shorted internally, blowing the fuse.
Old May 24, 2004 | 08:33 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
The EGR runs off the 'gages' fuse also. Check the EGR wiring around the plenum for shorted wires....this happened to me before. It would blow the fuse, I'd have no VSS signal, and no more TCC lockup.
Old May 24, 2004 | 11:45 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
I'll check al the wires but why dont TCC engage in D, is it something in the valvebody or does the ECM gets some signal frpm the shifter?
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Cameeeero
Sep 18, 2015 04:00 PM
CORV3TT3
Aug 23, 2015 11:26 AM
redmaroz
Aug 16, 2015 11:40 PM
