axle shaft differents
Old May 26, 2004 | 10:38 PM
1tinindian's Avatar
Car: 1983 WS-6 Trans Am
Engine: 1999 L31 5.7 Vortec
Transmission: 5 speed
Axle/Gears: Auburn Limited-slip w/3:73 gears
I have recently learned that there are 2 different part numbers for the axle shafts used on 3rd gens, one for the disc brake rear, and one for the drum rear.
My question is, what are different between the two?
Can the shafts out of a drum rear, work in a disc rear?
The drum rear axles are still available from GM, and the disc axles are discontinued.
I'm only concerned with the 7.5 rear, NOT the aussie 9 bolt.
Thanks, and I only really need some hard facts on this, as I have already played the guessing game with my dealership parts dept. and have gotten nowhere.
Old May 26, 2004 | 11:27 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The disc axles have a smaller diameter flange where the wheel studs are, to fit inside the rotor. Some older drum axles won't fit in a disc rotor.
Disc axles will always work in a drum rear.
It's entirely possible that they are now all the disc brake diameter, and they simply deleted the redundant part #.
Old May 27, 2004 | 10:18 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
werent there different spline axels offered on them also??
Old May 28, 2004 | 05:02 AM
ede's Avatar
ede
90 and up were 28 spline. 88 and lower were 26 splines, 89 was a transition year and could be either.
Old May 28, 2004 | 07:44 AM
THEGENERAL's Avatar
thats what i was thinking thanks for the info ede
Old May 28, 2004 | 08:55 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Right; if they still service the 26-spline axles, then there would still be 2 part #s, one for 26 and one for 28. But not one for disc and one for drum.
BAMiller
Sep 14, 2015 06:38 PM
Formula_88AE
Sep 3, 2015 01:47 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
tonys91rs
Sep 2, 2015 07:07 PM
greenyone
Sep 2, 2015 03:39 PM
