Changeing Rearend fluid
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I have a 91 camaro v6 with Limited Slip I got mobil 1 75-90 Gear oil and i also got the posi addative. Do i need to add the addative or can i just use the mobil 1 the addative was 3 dollars i jsut dont want to mess up my rearend gears.
Car: 4
Engine: 6
Transmission: 5
I'd a;mpst bet money it doesn't have limited slip, unless you put it there yourself. So unless you personally installed it (or paid somebody to do it), I wouldn't worry aboiut the additive.
If it really is a posi, you do need it however.
Liej ede said, the stuff from GM is much better, get that instead .... if you really have a posi.
Basicly when i floor the car the passanger side tire will spin and the drive side one will chatter trying to get grip. That would be limited slip right? So would i need the addative with that. The addative i got is made by trans X.
maroe624
Apr 16, 2017 08:29 AM
Thornburg
Aug 25, 2015 01:46 AM
92camaroJoe
Aug 13, 2015 06:07 AM
