No magnet in Tranny pan
Old Jun 9, 2004 | 02:23 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I jsut got a new chrome tranny pan with a drain plug btu it does not have a magnet in it. Is the magnet really necessary? Can i take the magnet out of my old pan? Or is there an after markert magnet i can put in?
Any input would be great
Old Jun 9, 2004 | 02:33 PM
ede's Avatar
ede
should be able to use the old magnet in the new pan
Old Jun 9, 2004 | 02:35 PM
FAST RS's Avatar
Does the old magnet just pop out? Also last time i changed it there was a gummy film over the magnet should i clean that film off or is it there for a reason.
Old Jun 9, 2004 | 06:13 PM
chevypower's Avatar
Car: '89 Formula, '97 Z28, '88 Formula 350
Engine: 305 TBI(LO3)
Transmission: TH700R4(MD8)
Just clean it with some carb cleaner.
Old Jun 12, 2004 | 11:00 PM
Eightyninef's Avatar
carb cleaner won't remove the metal shavings from the magnet.
you have to physically remove them with a rag or similiar
Old Jun 12, 2004 | 11:17 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
The "gummy film" on the magnet is friction materal from your clutch packs, as well as metal filings from your steels and hard internals.
It is common to find this on older transmissions, but its DEFINITELY nessesary to keep the magnet. The magnet attracts metal particles that could get caught up in the filter and clog the transmission badly. This is one cheap part you really want to keep.
Old Jun 13, 2004 | 02:27 AM
FAST RS's Avatar
I took out the magnet it wa easier then i thought i assumed it was tac welded in like the magnet in my differental cover it poped out easy put some TB cleaner on it wiped it with a rag and stuck it in the new pan. The new pan also has a magnet in the drain plug but its kinda small. I paid 12 bucks for the tranny pan on ebay it fit like a glove no modafacations needed bolt hols were perfect and it fit perfect. And the chrome on it was a deacent job. All i wanted was the drain plug.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88CamZ
Oct 8, 2015 10:29 AM
loud91rs
Oct 5, 2015 10:05 PM
bjpotter
Oct 4, 2015 07:48 PM
