whinning noise out of t-5
Subscribe
Jun 10, 2004 | 11:29 PM
I just put a t-5 in my 90 rs. i bought it used. When i drive it seems to whine in every gear but 5th. does anyone know what could be up with it.
Reply 0
Jun 10, 2004 | 11:53 PM
Re: whinning noise out of t-5
Quote:
Do you have a stock or aftermarket shifter?
Reply 0
Jun 11, 2004 | 04:13 PM
If it's whining fairly loudly then the bearings are most likely worn. Does it ever grind when shifting gears?
Reply 0
Jun 11, 2004 | 07:11 PM
mine whines a little to but i think its mostly my rearend because it has 160k on it... im just waiting for it to come loose so i can put in my new posi disc rear
does your rear whine?
Reply 0
Jun 13, 2004 | 07:42 PM
i has a stock shifter. my rear end does whine a little bit but it is comming from the tranny. i doesn't grind unless i don't push the clutch in far enough.
Reply 0
Subscribe
