Fluid change = More power??
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Today i changed my tranny fluid and filter i used max life ATF as the replacement fluid. Then i decided to change my rearend fluid i used Mobil 1 Gear oil and the LTD slip addative. When i was done i took it out for a spin and flored it. I was able to actualy leave tracks through a intersection which i had not been able to do before. I have a V6 with 3.23 gears. Would the fluid change make me have more power?
Transmission: 4L80E/4L80E
Are you sure you didn't spill any fluid onto the tires???
Actually, the fluids won't make you have more power. They could, however, reduce the amount of power being consumed by those drivetrain components.
MaxLife ATF isn't synthetic, is it?
I'd guess the gear lube change had the most to do with the butt-dyno effect. Especially if it was the factory fill that you drained out.
maroe624
Apr 16, 2017 08:29 AM
backtothe80s
Sep 5, 2015 12:39 AM
Thornburg
Aug 25, 2015 01:46 AM
92camaroJoe
Aug 13, 2015 06:07 AM
