is my 700r4 shot?
Old Jun 16, 2004 | 04:10 AM
1986camarojoe's Avatar
Car: Z28
Engine: 310
is my 700r4 shot?
Alright heres what happens. If I put the car in drive it'll shift into 2nd but only goes to about 45mph and starts revving up real high. If I put the car in 1st and leave it there itll shift on its own and I can drive 55 mph at 3000rpm. Even though I can drive it if I leave the shifter in 1st it seems like a few too many RPM and it will not go through all the gears. So far I've adjusted the shifter linkage and the TV cable with no luck.
Old Jun 16, 2004 | 09:05 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
The trans is slipping. A lot of people are quick to blame problems like this on the TV cable. It never solves the problem. Basically the clutches are worn out and the trans needs to be either rebuilt or replaced.
Old Jun 16, 2004 | 10:50 PM
Car: Z28
Engine: 310
Yea I figured it wouldn't be an easy fix. Oh well I guess I'll find a th350 to put in. Thanks for the info.
Mirror Image
Oct 29, 2017 09:51 PM
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
