Hurst Quarter Stick & 700R4 ?
Old Jun 16, 2004 | 04:53 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Ok I have used a Hurst Quarter Stick on a TH-350 in my last camaro but on this one I am going to use a Pro Built Automatics 700R4 With a Vacuum Lock Up Kit. In Place of the Current T-5, It is hitting the Road.
Now My question is for the lock up to work correctly its got to know when Your in 4th (OD) Does the Hurst Quarter Stick designed for a 700R4 have a 4th gear Switch.
Old Jun 16, 2004 | 06:01 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The shifter has nothing to do with control of the TCC.
Old Jun 16, 2004 | 07:03 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
well how does the ecm and everything know when you have the shifter placed in 4th
There is something I am no understanding Some one plese Explain.
Old Jun 16, 2004 | 08:44 PM
krly79's Avatar
Car: '93 S10 Short bed standard cab
Engine: 383 Stroker
Transmission: 92' stage 2 700r4 w/3600 stall
if you have it in 4th and put in in third, then it pulls the shifter cable and moves your linkage on your transmission from 4th to 3rd and it is all internal to your tranny.
Old Jun 16, 2004 | 10:13 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The ECM doesn't care at all what position the shifter is in, it will lock up the TCC whenever it wants regardless. There is a 4th gear switch in the transmission that tells the ECM when the transmission actually shifts into 4th gear, but it doesn't seem to have much to do with the TCC.
Old Jun 17, 2004 | 05:50 AM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Ahhh I see it is in the tranny. I realized this last night at work. I work 3rd and around 3:00 am I said DUH
Old Jun 17, 2004 | 11:39 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The only switches on the shifter are for the reverse lights, which you'd need to be street legal, and the park/neutral switch, which you'd need to be legal at the track.
ZEEYAA
Apr 16, 2023 08:29 PM
jrdturbo
Mar 31, 2016 02:58 PM
LC2 TECH
Oct 13, 2015 11:53 PM
ndndndnd
Sep 28, 2015 08:00 AM
6998poncho
Sep 25, 2015 02:56 PM
