TH350 problem....
Old Jun 20, 2004 | 07:54 PM
flowmasterchevy's Avatar
Car: '91 RS, F41
Transmission: WC T5
TH350 problem....
My th350 tranny will not come out of low gear, has anyone ever had this problem before?? I pulled the pan, and the small "S" clip had came off and the linkage slipped out of place, so i fixed that and put the pan back on and it still does this... anyone know what the h#$@ is goin on here????
Old Jun 20, 2004 | 10:36 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You need a vacuum signal to make the tranny shift. It connects to the vacuum modulator on the passenger side to the tranny.
Old Jun 21, 2004 | 11:39 AM
Car: '91 RS, F41
Transmission: WC T5
so that would keep in hung up in low gear??
Old Jun 21, 2004 | 11:49 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Yes the tranny won't shift.
Old Jun 21, 2004 | 07:44 PM
Car: '91 RS, F41
Transmission: WC T5
no, thats not it, it was still hooked up....
any other suggestions?
Old Jun 21, 2004 | 11:12 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Is your tranny fluid low? I know the vacuum line is connected but is it connected to a vacuum sorce, so it sees vacuum.
Old Jun 22, 2004 | 09:31 AM
Car: '91 RS, F41
Transmission: WC T5
yeah i checked both ends... they were both connected, and there was vaccum on the line... someone else suggested that i drop the valve body and check for a stuck valve....thanks
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
romcjr
Sep 17, 2015 05:18 PM
LittleFranks
Sep 17, 2015 12:22 PM
89newfun
Sep 16, 2015 09:28 AM
383cam
Sep 9, 2015 06:01 AM
