no fifth gear
Old Jun 21, 2004 | 12:24 PM
gtaeric's Avatar
Car: '88
Engine: 305tpi
Transmission: t-5
no fifth gear
Ever since I bought my GTA, fifth gear has been "missing". Moving the shifter into the fifth gear position takes no resistance, theres no grinding even without using the clutch, just nothing. All the other gears work fine, even reverse. Any ideas what could be causing this?
Old Jun 21, 2004 | 12:42 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Broken shift fork, broken or missing roll pin for it, trashed fifth gear
Old Jun 21, 2004 | 04:22 PM
gtaeric's Avatar
Car: '88
Engine: 305tpi
Transmission: t-5
Can I check anything externally? Or will I have to open it up to look at it?
Old Jun 21, 2004 | 04:47 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's all internal. Nothing you can see from outside.
Old Jun 21, 2004 | 06:46 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
MY guess would be that the snap ring popped off or broke. That is exactly how mine acted when the snap ring popped out.
The trany has to be taken apart to get to it.
You can see in the below pic that the snap ring came out of its grove and the 5th gear was allowed to slide back and no longer engagues the main shaft.
See pic below:
Old Jun 21, 2004 | 06:47 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
