Question........
Old Jun 21, 2004 | 04:40 PM
zapr's Avatar
Car: 1985 camaro z28
Engine: 305 lg4
Question........
......Excuse my ignorance, but when a transmission slips, what exactly does this mean and what does the tranny do that indicates slipping?.........Zapr.
Old Jun 21, 2004 | 04:43 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Isn't going into gear correctly. Your giving it gas and its revving higher than normal and finally jerks into gear. Im not sure on the technical parts because i've never torn into a automatic.
Old Jun 23, 2004 | 03:01 PM
zapr's Avatar
Engine: 305 lg4
........My car will down shift from forth to third with part throttle and then go back and fourth between third and fourth unless I floor it or let off. Any idea what this might be? Thanks......Zapr.
Old Jun 23, 2004 | 03:08 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A "slip" is when you're giving it gas in gear and it feels "loose", like not all the power is getting to the wheels.
What you're describing sounds more like a "flare", which is when it's shifting gears and it comes out of one gear and then there's a period where it feels like it's in neutral before it goes into the next gear.
Old Jun 24, 2004 | 11:34 AM
zapr's Avatar
Engine: 305 lg4
.......How do you correct this flare? Is it just an adjustment or is it more complicated? It only does it in third gear. Thanks........Zapr.
Old Jun 24, 2004 | 11:59 AM
flowmasterchevy's Avatar
Car: '91 RS, F41
Transmission: WC T5
it sounds to me like your going just fast enough for the tranny to want to kick into overdrive, but then it bogs down and takes itself back into third...you might wanna keep it in 3rd until you hit about 50 mph or 55mph and then put it into overdrive....
