Where is the lockup connector plug on the 700R4?
Old Jun 26, 2004 | 01:15 PM
StealthElephant's Avatar
Car: 87' Iroc
I'm trying to wire my lockup to a manual switch since I got rid of the TPI, I went under my car and couldn't find the connector on either side of the trans. I only saw trans flud lines on the passenger side. I didn't see any connector or wires coming from it.
Old Jun 26, 2004 | 02:23 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Drivers side of the transmission. It actually located on a small 2in tower casting near the back. If you look at the gear selctor lever and work back you will see a plastic peice poking up before you reach the tailhousing.
Old Jun 26, 2004 | 02:48 PM
Car: 87' Iroc
The only line I noticed was a 1/4"diamter plastic tube that ran along the chassis then plugged ALL the way in the back of the trans near the tail. Was that it? It wasn't a "plug". It looked like it screwed off. Will I have to cut that line, put 12v from a switch to that connector then screw it back in?
Old Jun 27, 2004 | 01:28 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
That's the speedometer cable. It's forward of that, facing up, not on the side.
Old Jun 27, 2004 | 12:07 PM
MdFormula350's Avatar
here's a pic, might help some.
Attached Thumbnails Where is the lockup connector plug on the 700R4?-700_picture.jpg
Old Jun 27, 2004 | 04:33 PM
Car: 87' Iroc
That pic is awesome...thnx for the info.
eightsixseven
Dec 16, 2024 01:50 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
stalkier
Dec 6, 2015 11:25 PM
Eric-86sc
Aug 24, 2015 09:01 PM
g.l.mos
Aug 22, 2015 12:02 AM
