Loosing Atf
Old Jul 13, 2004 | 11:40 AM
ryantherock's Avatar
Loosing Atf
On my 305 TPI 86 IROC i am loosing automatic transmission fluid (i think) around the dipstick tube. does anyone have an idea of how to fix this ? If anyone can give me some directions it will be appreciated.
thanks, ryan
Old Jul 13, 2004 | 12:34 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
if im not mistaken there is a little rubber seal there. perhaps it's old and cracked, or your dipstick is coming out.
If you try to move the dipstick around, is it loose?
Old Jul 13, 2004 | 12:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Moving to Tranny forum.
Old Jul 13, 2004 | 12:59 PM
ljnowell's Avatar
Remove dipstick tube, replace rubber grommet, reinstall dipstick tube. Becareful when installing, the grommets tear very easily.
Old Jul 13, 2004 | 10:05 PM
not to sound stupid ! but how does one remove the dipstick tube ??? sorry but never done this before ?
thanks
ryan
Old Jul 13, 2004 | 10:13 PM
ljnowell's Avatar
Loosen the bolt at the bellhousing (that holds the dipstick tube bracket) and pull it out.
Old Jul 14, 2004 | 08:15 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
yeah just loosen it up and pull it up about 3 inches then climb back under the car and replace the o ring on it if its not that leaking check the tv cable where it meets the trasmission sometimes they will leak there also and it also has an o ring on it
83 Crossfire TA
Jan 3, 2016 01:26 PM
92camaro350cci
Oct 14, 2015 09:29 AM
budowski
Carburetors
Oct 2, 2015 10:16 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
reactor60
Sep 22, 2015 01:44 PM
