bad clutch?
Old Jul 14, 2004 | 09:54 AM
brokedowncamaro's Avatar
Car: 89' RS camaro
Engine: 2.8....350 in the making
bad clutch?
i went to go drive my the other day and it was grinding into reverse and when it finally cot and went out the driveway i put it in 1st and it went but very slowly and and revved really high, same for 2nd and 3rd. and then it just gave up and wudnt go nowhere? is it the clutch?? *also there was a burning smell coming from under the car*
Old Jul 14, 2004 | 10:21 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yup, that sounds alot like the clutch is smoked.
Old Jul 14, 2004 | 10:30 AM
Car: 89' RS camaro
ok well ill try and get the old out and have it replaced...but any other suggestions are greatly appreciated. thanks. Dave.
Old Jul 14, 2004 | 11:55 AM
Car: 89' RS camaro
ok well started the car and tryed to drop it in gear and it wudnt go nowhere. ran thru all gears and nothing, not even reverse. so its thte clutch then right??
Old Jul 19, 2004 | 01:59 PM
91Z-TheReaper's Avatar
Car: 88 IROC
Engine: 350 L98
Transmission: T5 - 5 Speed
Any Diagnosis Yet?
I seem to be having the same rear grind problem. I still have all my gears and it is only occassionally having the forward motion problem that you have had. I'm just curious because maybe I can 'help' mine before its too late.
Old Jul 19, 2004 | 02:55 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
i remember reading on here (dont know if it was a proven fact, but i bet somebody knows) that there is no syncro for reverse i know mine would grind if i was moving even the slightest little bit, so i would use one foot on the clutch other on the brake when going into reverse, and it never grinded
Drone358
Dec 10, 2015 08:16 PM
jtwoods4
Sep 3, 2015 05:39 PM
tonys91rs
Sep 2, 2015 07:07 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
