new th350 won't go into gear
Car: 1991 camaro rs
Engine: 383 stroker
Transmission: th350
we just finished everything up today...hooked up the vacuum lines and poured some ATF in started the car and when i tried to put it into gear...nothing. it just revs like it was in neutral or park. could this be a fluid issue, tranny was bone dry when we put it in so does it need more than the recommended fluid amount? thanks for any help.
Car: 4
Engine: 6
Transmission: 5
It should take between 10 and 11 quarts of fluid.
Pour in about 5 or 6, then start the engine, then pour in 4 more as quickly as possible; then let it warm up, and top it off.
Car: 1991 camaro rs
Engine: 383 stroker
Transmission: th350
ok, well solved that problem car drives now!!!! Thanks a lot RB83L69. Now i've got another question, the guy who rebuilt this trans said he put a shift kit in it but when i'm driving it i feel the hesitation for it to go in to gear when i upshift manually, is this a vacuum modulator thing? Oh yeah, is there a break in period for a rebuilt trans?
junkcltr
Aug 2, 2019 11:12 PM
hectre13
Aug 26, 2015 08:17 AM
