Bolt Size question
Old Jul 18, 2004 | 08:37 AM
LowRyder's Avatar
Car: 92 RS Vert
Engine: 355
Axle/Gears: 342
Bolt Size question
Hey guys I need to know the size of the bolts that mount the tranny through the belhousing. Somehow my buddy lost the bolts on his and i have no idea what size they are. Any help would be greatly appreciated. its the 4 larger bolts on the T5
Old Jul 18, 2004 | 08:59 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
10mm x whatever the "standard" (not fine) metric thread is for that diameter x 40mm long
Old Jul 18, 2004 | 10:00 AM
LowRyder's Avatar
Car: 92 RS Vert
Engine: 355
Axle/Gears: 342
those bolts just slide in.. their 2 thin, are you sure that's the size?
thanx
Old Jul 18, 2004 | 12:05 PM
WECoyote's Avatar
Try M12 x 1.75(pitch) x 40mm long. Make sure you use grade 8 (8.8 or 10.8 metric/ISO eqv.?) bolts.
Mike
BTW...I got that info directly from a Camaro Illustrated Parts book.
Old Jul 18, 2004 | 12:51 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
12.... sorry about that.... guess I should have gone and looked at them instead of trying to remember off the top of my head. They have 15mm hex heads, which is what usually goes with 10mm.
Old Jul 19, 2004 | 01:54 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
The top right one can be easier to put in if it's an original GM bolt because it has a Torx 45 or 50 in it and the 15mm head RB mentioned. I would get new GM ones myself.
Old Jul 19, 2004 | 08:48 AM
LowRyder's Avatar
Car: 92 RS Vert
Engine: 355
Axle/Gears: 342
Thanx a lot guys!
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
toronto formula
Nov 10, 2015 06:17 AM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
knight72
Aug 10, 2015 09:32 PM
