Speedo gear part #'s
Old Jul 22, 2004 | 02:25 PM
25THRSS's Avatar
I already did a search, and came up with a lot of info on the cable driven speedo's, but not too much on the electric vss cars like my 92 RS. I need to know the gm part #'s for the 15 tooth drive and the 41 tooth driven gears for my 92 auto RS. Also, is there a different vss I need to order to work with the new gears?
Old Jul 23, 2004 | 12:50 AM
slow91camaro's Avatar
Car: '91 Camaro Z-28
Transmission: auto
I found this for the for the 15 tooth in the FAQ section:
"With drive gear number 8642620, (gray, 15 teeth) the following combinations apply:"
I also found this:
25513048 41 Yello 25007339 (first # is the gear part # and the second is for the sleeve)
I just installed the grey (15 teeth) gear in my car with an electric speedo so I can confidently say that is the correct part number. The yellow gear (41 teeth) I'm not so sure about. I don't know if it's a cable part#, vss part# or both.
Old Jul 23, 2004 | 12:55 AM
Transmission: auto
Never mind. I just noticed someone gave you a complete list in another thread.
Old Jul 23, 2004 | 12:56 AM
25THRSS's Avatar
I'm almost positive I have the correct speedo gear #'s.
15 tooth drive= 8642620
41 tooth driven= 25513048
What I'm not certain on is the correct vss for that combination. The # 25007339 you listed doesn't exist according to gmpartsdirect. What is the part # for the correct vss I need?
Old Jul 23, 2004 | 12:42 PM
Transmission: auto
Sorry, I have no clue on that. The gear and sleeve part numbers I provided are from the Thirdgen.org "FAQ" section found on the home page. The gears are a little over half way down the "FAQ" page. Hope this helps.
https://www.thirdgen.org/newdesign/faq/thirdgen.shtml
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
