Anyone heard of a T5Z?
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I ran across a tidbit of info about T5 trannys and something was mentioned about a stronger T5 called a T5Z. Supposedly for Mustangs but I was curious to know if it could be available for GM use.
Car: `86 SS / `87 SS
the main item of strength added is the tapered roller bearing added to the leading edge of the mainshaft, and the race is within the rear of the input shaft. Definitely a good strenth item to add to a T5, and I believe it can be added to the GM T5s; Hanlon might do it?
