Wrong flywheel??
Old Jul 29, 2004 | 11:04 AM
ChallengeR's Avatar
Car: Trans Am 87
Engine: 305 soon to be 350
Transmission: 700R4 soon to be T5
Wrong flywheel??
Ive buy a manual setup from a guy how had a 86 camaro....and tomorow when im gonna put it in i see that my new flywheel had a biger bolt patern than my crank...is there flywheel for 1 pieces rear and 2 pieces rear??? and if i buy a new flywheel...it fit on my clutch and pressure plate that i already had?? and...the number of tooth on the flywheel how i know what to buy??? plz help me....im so confused a this time
Old Jul 29, 2004 | 11:11 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes there are different flywheels.
Yes your clutch will fit, if it's for a Camaro / Firebird with a V8. (assuming of course that you're working on a V8, sounds like it)
You need a 12.8" flywheel with 153 teeth for a 10.4" clutch. It's the stock flywheel for a 86-92 305 5-speed Camaro / Firebird. There are actually 2 stock ones that will work; one is lightweight and was used on L69 and TPI motors, the other is heavier and was used on the base-model LG4 and TBI ones.
ede's Avatar
ede
yes bolt pattern is differant for one piece and two pice crank seals, also the one piece seal cranks have a dowell to locate the flywhhel. the reason is when they went to the once piece seal mass was removed from the flywheel mounting flange and to make up for it weight was added to the flywheel. this tends to make people want to think the one piece crank seal engines became externally balanced when in fact they remained internally balanced.
Old Jul 29, 2004 | 06:34 PM
ChallengeR's Avatar
Car: Trans Am 87
Big thnx to you guys!!! now....i want a 153 tooth flywheel for 1 pieces rear main seal!!!
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
