Oh man, why did this happen?? Pics inside...
Old Aug 2, 2004 | 01:27 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Took it to the track Friday night (7/30) to establish a baseline before I change stuff. First pass, did a nice 2nd gear burnout for about 5 seconds, rolled up ans staged. Launched from 3k, with just a minor tire spin. wound up through first and power shifted into second at 6k. Wound up through second and went for the 2-3 powershift and MISSED...or so I thought. Then I couldn't get it in 3rd. Foked around for a few seconds, and finally ground it into 3rd. Wound up through 3rd, and went for the 3-4 and MISSED! Totally pissed off, I farted around w/ the shifter and clutch and finally ground/banged into 4th.
After the pass was over I couldn't shift it at all! Untill I came to a complete stop, and then everything returned to normal. Same thing on my second pass, except worse. The clutch wouldn't release at all, and I ended up having to RPM-match-shift each gear. Boooo! The clutch would only release at a stop. I decided to drive it home carefully to Park City, knowing the clutch wouldn't release at speed, and that I'd have to RMP-match every shift. I managed to get about 10 miles from the track (still about 20 miles from home) and while cruising along at about 65 mpg in 6th gear....BAM! BOOM! WHAMMO! ba-bang, cha-chang, ba-da, ba-da, ba-da, ba-da...
I coasted off the road and parked it in a hotel parking lot. Flat bedded it home Saturday and pulled the trans yesterday. Here's the out come...
Attached Thumbnails Oh man, why did this happen??  Pics inside...-clutch3b.jpg
Old Aug 2, 2004 | 01:42 PM
Flyte risk's Avatar
Car: 85 IROC
Engine: tree-oh-five
Transmission: 700, but the T-56 is laying on the floor
I'd say a 3K launch and a 6K powershift with anything close to traction would do that. Weakest link in the chain is always the one that goes.
Old Aug 2, 2004 | 01:51 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Did you check to see how many feet you have left?
You should be giving some kind of thanks to a higher power for that; I know people in wheelchairs, from that exact failure.
Old Aug 2, 2004 | 02:25 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
so what clutch was that? looks like stock or stock replacement like Zoom or somthing....
RB: heh, you arnt kidding...
athough i tried to put a shield on when i put my bellhousing on... i couldnt get it to fit.
its always the simple things that save your ***... lil loctite, DS loop, fire extinguisher, ect....
Old Aug 2, 2004 | 03:21 PM
Engine: LT1, L400
I still have two feet, which I'm pretty happy about, 'cause waterskiing(my other summer sport) on one foot would suck.
It was a stock clutch (Valeo) that came out of a '95 LT1 Camaro from years ago, thoughit probably has less than 10k on it.
I'm surprised a stocker couldn't handle that. It's not like I was asking THAT much of it.
BTW, my 60' was a average 2.2xx so obviously I wasn't putting an ridiculous load on it.
Old Aug 2, 2004 | 03:38 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
It was a stock clutch (Valeo) that came out of a '95 LT1 Camero from years ago, thoughit probably has less than 10k on it.
jeez... you guys have to really learn how to spell CAMARO right!
Old Aug 2, 2004 | 04:34 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
G*d damn you got lucky man!! That could have been the least of your worries!
Old Aug 2, 2004 | 08:22 PM
Ivon1877's Avatar
Car: 1990 Camaro RS with T-Tops
Engine: 312 TBI(305) 0.040 over
Transmission: out of a v-6 s-10 blazer!
Damn that looks nice compare to the one that came out of my truck!
I have a 2000 silverado with a v-6 and i was down shifting from 2nd to 1st and mine exploded into a thousand pieces and broke a couple of the metal fins off! It wouldnt move!! had it towed home!
Attached Thumbnails Oh man, why did this happen??  Pics inside...-clutchdestroyed.jpg
Old Aug 3, 2004 | 12:05 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
i agree, lol.
Old Aug 3, 2004 | 12:25 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Well Tom, I think you may have found the problem....
Looks like it's time for a better clutch ehh?? Nice car you have now BTW. Hope your luck gets better with it.
Oh, and skiing with one foot is cool!! But not when it's out of necessity!! (sp).....
Old Aug 3, 2004 | 12:36 AM
87Formula4bbl's Avatar
Car: '87 Formula
Re: Oh man, why did this happen?? Pics inside...
...and while cruising along at about 65 mpg in 6th gear....
Wow, I wish I got that kind of mileage...
jk with ya, wow that stinks man, good thing thats all the damage it did though.
Hotrodboba400
Dec 10, 2019 07:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Fronzizzle
Sep 8, 2015 12:10 PM
rsrookie
Sep 5, 2015 07:08 PM
