Weight gain with 9" and 12-bolt rear ends?
Old Aug 6, 2004 | 04:54 PM
Rembrandt's Avatar
I've been wondering and info is hard to find, but does anyone have a good idea of how much weight you gain when upgrading to a 9" or 12-bolt rear end?
I know the 9" outweighs the 12-bolt, but not by how much.
What about 9" rear ends with aluminum center sections? How much weight do you drop? Is there a significant strength tradeoff compared to a total iron/steel rear?
Old Aug 6, 2004 | 08:31 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Actually, the 12-bolt is heavier than the 9". I remember reading it was something like 12 lbs more. On average.
Old Aug 8, 2004 | 01:01 AM
Triaged's Avatar
I think I got this from Hot Rod's web site.
If you subtract the weight of the drum brakes the 12B is a good amount lighter.
Old Aug 10, 2004 | 06:39 PM
jreese's Avatar
Car: '89 Black 305 TBI Firebird "Eleanor"
Engine: V8 5.0L (LO3)
Transmission: T5 Manual (hurst shifter)
how do you differientiate between what bolt a rear end is? Which bolts do you count? I know I am ignorant, but bear with me.
Old Aug 10, 2004 | 07:23 PM
Triaged's Avatar
It goes by the # of bolts on the diff cover.
Many people believe in error that it is actually by ring gear bolts...but all 3 14-bolts have 12 bolts holding on the ring gear. A more specific way to to denote a axle is by the ring gear size (like a ford 9") because there are many different size 10-bolts, and 14-bolts.
Old Aug 10, 2004 | 07:36 PM
jreese's Avatar
that cover is the one in the middle of the axle that faces toward the rear?
Old Aug 11, 2004 | 12:12 AM
Triaged's Avatar
yep
Old Aug 19, 2004 | 02:01 AM
cdh67's Avatar
Car: 84 Z..err 92 now
Engine: 402 LS1 Procharged-14 psi-629 hp!
Add 14 pounds for the torque arm mount
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
