TH-200 to TH-350 swap QUESTIONS
Old Aug 7, 2004 | 05:50 PM
DaGreatKobe's Avatar
Car: '87 Z28, '91 Z28
Engine: 305 carbed, 305 tpi
Transmission: 200TH, 700R4
are there any new parts that i need in particular? i have a very old th-200 in my '82 camaro. and i have a '82 monte carlo with a rebuilt 350 that i am getting rid of but im keeping the tranny. are there any modifications or parts that i need to do this swap? are the transmissions the same size?
Old Aug 8, 2004 | 12:06 PM
carbed82_Z28's Avatar
Car: 82 Z28
Engine: She's motor-less!
Transmission: th-350
If you have an 82 then you shouldnt need anything but a B&M Torque Arm mount bracket..THere like 80 something ..call jegs ..As for the drive shaft, when i swaped my 200 for a 350, the drive shaft fit perfectly in my 82..so i dunno if you will have problems..The crossmember should line up, mine did...so....
Old Aug 8, 2004 | 05:38 PM
thanks i found it for $80 on summitracing.com. so thats all i need?
Old Aug 8, 2004 | 07:34 PM
Car: 82 Z28
Thats all i needed...My drive shaft worked and the crossmember bolts lined up..
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
