Help Me Now! Asap!!!!!!!
Old Aug 7, 2004 | 10:44 PM
jake_91_rs's Avatar
Car: 1991 RS Camaro
Transmission: 5sp
ok i'm driving down the road today and i see a bunch of smoke coming from under the car so i pull over and the exhaust is steaming hot and there is something on it so i get the car home and look under it and it looks like to me it is rearend fluid......its not red and most of it is fromt he back of the car....it looks like dirty oil.....the car has been wheel hopping really bad latley just b/c of the sticker 17 inch tires and wheels.....is it the front rear end seal or possibly something else........help me now i'm gona try to fix it tomorrow so info is much needed ASAP
Old Aug 8, 2004 | 02:37 AM
taonindo's Avatar
Car: 82 firebird
Engine: 406
only way to know for sure is to take a look see ... get ahold of the rear end yoke and see if you can move it back and forth ... if it moves then you have more problems than a seal ... you could pull the cover and see if there is fluid in it that may help to isolate where it is comming from ... hope this helps some ... tao
Old Aug 9, 2004 | 12:03 AM
onebinky's Avatar
There's also a plug on the right side of the pumpkin under the thick ridge. The oil level should be up to the bottom of the hole. If you haven't had the rear open yet, now might be the time to pull the cover and check it all out.
92GTA
Apr 9, 2016 07:39 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Brother Al
Oct 14, 2015 06:39 AM
92projectcamaro
Sep 24, 2015 08:09 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
