weird trans problem
Old Aug 7, 2004 | 12:56 AM
level's Avatar
Car: 1987 transam
Engine: 383 /w superram
Transmission: 700r4 /w 2800rpm stall
weird trans problem
i have a 2800rpm stall in my car with a 700r4 trans.. when i'm comming to a stop the engine wants to die as if the trans is forcing the rpms down on the motor.. and if i let off the gas while the car is coasting it tries to slowdown quickly? i have no clue whats going on.. the only thing that isn't connected on the trans is the VSS could this cause it?
the car also has absolutely no ***** whats so ever unless i nail hammer from a stop then it takes off spinning the tires into 3rd
is this thing stuck in "lockup" or something
Old Aug 7, 2004 | 07:30 AM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Sounds to me like your lockup is acting a little wierd
Old Aug 7, 2004 | 02:22 PM
level's Avatar
Car: 1987 transam
obveusly.. uhm how do i fix it?
Old Aug 7, 2004 | 03:09 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Wire the lockup to a switch.... :lala:
Old Aug 7, 2004 | 08:26 PM
level's Avatar
Car: 1987 transam
thats butchering it.. its supost to lock/unlock on
its own..
Old Aug 8, 2004 | 12:57 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
TV cable needs adjusting or has come loose from the bracket near the carb.?
Jim.
Old Aug 8, 2004 | 09:26 PM
Nutty91RS's Avatar
Car: 91 Camaro RS
Engine: 87 350 tpi
Transmission: junk 700r4
VSS could be culprit
The lockup is controlled bye the VSS, there is a way to wire it up so it'll only lockup in fourth but that may not be the solution you're looking for considering the 2800 stall. This link shows you 1 way to get 4th lockup only http://www.highperformancecars.com/crosley/lockup1.htm
I ended up running mine to a switch, locks up on it's own in 4th, and I can manually switch the lockup on in 2nd and 3rd, works like a charm.
Old Aug 8, 2004 | 09:29 PM
Nutty91RS's Avatar
Car: 91 Camaro RS
Engine: 87 350 tpi
Here's the other link, it takes some wading through but this is the way I went http://purplesagetradingpost.com/sum...o/700R4p1.html
Old Aug 9, 2004 | 02:43 AM
level's Avatar
Car: 1987 transam
could it have to do with the kickdown cable bracket my superram came with a braket but i used the stock one maybe the cable isn't working right because of that?
Ghettobird52
Jul 5, 2024 11:18 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
maroe624
Apr 16, 2017 08:29 AM
sreZ28
Aug 14, 2015 07:48 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
