shift pattern
Old Aug 10, 2004 | 03:43 PM
Travis 82 z28's Avatar
Car: 82 z28
Engine: 355 chevy 4 bolt
Transmission: 4-speed
shift pattern
whats the correct shift pattern for the 82 z28 4-speed 83mm tranny?
r 1 3
2 4 or
1 3
r 2 4
the shift plate says diagram 2 is correct but actually works like diagram 1
Old Aug 10, 2004 | 04:29 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Diagram 1 is the Warner T-10; diagram 2 is the Saginaw. I have no idea which one has the 83mm mainshaft-to-countergear spacing.
Look at your transmission. If the case is aluminum with an iron inspection cover, and the reverse shifter shaft goes into the extension housing not the case, it's a Warner. If the whole case is cast iron and the reverse shifter shaft goes into the case not the extension housing, it's a Saginaw.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
