Need part # or size/dimensions of bolt and washer for transmission Xmember
Old Aug 12, 2004 | 04:18 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I just went to look at my car and I noticed my crossmember is hanging from one side . I must have lost two bolts somewhere. Anyone know the part #?
Old Aug 12, 2004 | 06:31 PM
WECoyote's Avatar
pasky,
Those 4 bolts that hold the trans cross member up are M10 x 1.5 pitch x 32mm long. The GM part number is: 11504293
The washers used with those bolts have GM part number: 14074908
I'm not sure if either of those numbers are still valid but you could check them out at GMPartsDirect.com
If you have an ACE or TrueValue Hardware (or eqv.) near by you may be able to get both the bolts and washers there. I would recommend using good grade (example 10.9) bolts and washers for safety reasons.
Use 'Never-seize' or equivalant on the threads before installing.
Torque to 35 ft-lbs
Mike
Old Aug 12, 2004 | 06:37 PM
pasky's Avatar
Thank you.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Reddeath210
Oct 6, 2015 08:20 AM
fonzie85
Aug 13, 2015 11:50 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
1nastygta
Aug 8, 2015 07:38 PM
