Can gears be set-up in an axle OFF the car?
...just like the title says.
...can you set up gears in an rear axle while the rear is outta the car?
*edit*...let me clarify, I know you can simply bolt it all together, I'm wondering if all the backspacing measurements etc. can be done properly...
Car: 4
Engine: 6
Transmission: 5
Yes.
Having the sheet metal wrapped around the rear, or not, doesn't affect how the moving parts fit in the housing.
Think about how the factory does it.
Cool.
I would've thought that you could, but didn't know if there were backspacing/preload issues and things like that to worry about.
I've never done anything to the rear-axle before, and I may try a gear swap myself.... ....we'll see.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
My friend does a lot of gears and prefers to get the rear axle by itself. that way he can do the gears without waiting on using a lift at the shop.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
