guys i need help badly
Old Aug 17, 2004 | 07:51 PM
86camedcamaro's Avatar
Transmission: 350 turbo
i am gonna swap from 700r4 to the 400 turbo tranny to meet with the stock drive shaft what size tail shaft do i need? and how much hp do yous think a 10 bolt rear can hold under a 383 stroker 13.5.1 compression soo on.. about 600hp. machine shop said.. going by hear say.
what size tail shaft do i need to meet with stock drive shaft?
Old Aug 18, 2004 | 01:18 PM
RaMaiRGoD69's Avatar
Car: 88 GTA
rearend
well i have heard that the 10 bolt can handle around 500 ft lbs and with you having an automatic tranny it will help but i doubt that rearend will last long with 600 hp and sticky tires....
I say drive it till it breaks then buy a moser!
sorry i dont know about the tailshaft.
Old Aug 18, 2004 | 01:47 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The 400 uses a different yoke from your stock drive shaft. No 400 will accept it.
Face it, you're going to be doing some custom drive shaft work.... $75 plus parts, you're done. Big whoop. Not particularly painful at all; in fact, I'd rate it as one of the least things to be all bothered about in a swap of that sort; far cheaper than a converter or a good-quality rebuild, and alot easier than the crossmember issue.
Old Aug 20, 2004 | 07:48 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
There is a way to use a short tail TH400 with a stock TH350 length driveshaft and a slip yoke from a 60's Buick application, but you don't have an 82 f-body (with all production transmissions the same lenght as a short tail TH350,) so your driveshaft will need changed no matter what.
86IROC112
Apr 9, 2016 10:20 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
Jae992
Aug 27, 2015 09:07 AM
Street Lethal
Aug 14, 2015 08:25 PM
