is this the correct gear?
Old Aug 18, 2004 | 02:23 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
http://store.summitracing.com/partde...N=120%20301350
3.73 ratio for 27spline, 2 series carrier.
7.5" ring gear diameter.
my car has the ****ty 2.77 in the rear end.
this 3.73 is the correct fitment for my rearend right?
Old Aug 18, 2004 | 02:32 PM
ede's Avatar
ede
you need a richmond pn 49-0007-1 3:73 for 3:08 and numerically lower carriers
Old Aug 18, 2004 | 03:10 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: is this the correct gear?
2:77 gears = 9-bolt rear and 7.5 gears only fit 10-bolt rears, so back to the drawning board.
Old Aug 18, 2004 | 06:55 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
I say seach the yards for a 3.45 gear out of a 9 bolt I think they came in the 87-90 lb9 manual trans
or try to find someone that seles new gears for the borg-warner/aussie diff
Old Aug 19, 2004 | 12:15 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
well ede said i need this part number: 49-0007-1
and that link i posted is to that exact part number!
so who is right? ede or DJP87Z28?
Old Aug 19, 2004 | 12:18 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Well if you have a 9-bolt then ede is wrong!
Old Aug 19, 2004 | 12:20 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I have ten bolts...
Old Aug 19, 2004 | 12:23 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Then you don't have 2.77 gears and ede is right.
Old Aug 19, 2004 | 12:25 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
im pretty sure i do..
G80
AXLE POSITRACTION, LIMITED SLIP
GH3
AXLE REAR, 2.77 RATIO
same with my RS, it had 3.08 and ten bolts.
Old Aug 19, 2004 | 12:33 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
ok i lied, i double checked, my 3.08 RS had 10 bolts, my 2.77 iroc does have 9 bolts.
so what do i need? both were 2-series carriers.
Old Aug 19, 2004 | 12:35 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
What car is this for now, the IROC with 2.77's? If so you are almost SOL, parts for 9-bolts are hard to find and are expensive. Nothing that summit has will work.
Old Aug 19, 2004 | 12:46 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
well crap
yes its for the iroc, i was using my RS for reference because it also had a 2-series carrier, and i just assumed my iroc was 10bolt as well..
now that i checked in person, it is 9 bolt
Old Aug 19, 2004 | 01:21 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
does this loook right?
http://www.reiderracing.com/gm912.htm
Old Aug 19, 2004 | 01:26 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Thats a 9.5" rear you want: http://www.reiderracing.com/gm734.htm
Old Aug 19, 2004 | 07:12 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Those won't fit either.... they're for a 3-series carrier. The 2.77 rear has a 2-series carrier.
AFAIK there are no "special" gears for the 9-bolt, and no ring gear spacers either. The ONLY way to upgrade a 2-series rear to 3-series gears, is to change out the carrier.
Old Aug 19, 2004 | 07:22 AM
DJP87Z28's Avatar
Well, back to the drawning board.
Old Aug 19, 2004 | 09:39 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You may want to spend some time reading this.
https://www.thirdgen.org/techbb2/sho...hreadid=239666
Old Aug 19, 2004 | 04:49 PM
ede's Avatar
ede
thanks, not often i'm right. actually i never picked up on the 2:77 ratio just sort of skimed it and seen 2:73 without really looking and seeing what it really said.
junkcltr
Aug 2, 2019 11:12 PM
hectre13
Aug 26, 2015 08:17 AM
Regal105
Aug 23, 2015 03:45 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
mizz0313
Aug 12, 2015 06:45 AM
