'84 700R4 - How is TCC controlled?
Old Aug 21, 2004 | 12:28 PM
BlazerMaro's Avatar
Does anyone know how the TCC is controlled on an '84 700R4? Not having an ECM, I am assuming it must be a mechanical/vacuum control. I'm trying to troubleshoot it, and the manual doesn't say a word about it.
Thanks!
Old Aug 21, 2004 | 02:04 PM
chris718's Avatar
it has a converor clutch shift valve that send torque convertor clutch oil signal to the lock up circuit at a pre determined gear ratio and vehicle speed(governor pressure)to allow lock up .other things are intertwined with this scheduling program depending on make and model
Old Aug 21, 2004 | 03:01 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Like chris718 says, you should have a governor valve to control lock-up at a certain speed. You should also have the usual solenoid in the valve body, however it will be internally grounded with only a single wire to pin A on the case connector as shown below. The solenoid works with a vaccuum switch on the firewall behind the brake booster to unlock the TCC during low vaccuum.
<img src="http://www3.telus.net/~crussel/tcc_wiring_4.gif" width=100%>
If you have a Haynes or Chilton manual, it will be useless to you for this. I believe the Helm manual does mention the governor valve in the transmission section, but for complete information you'd need the Canadian service manual supplement.
Old Aug 21, 2004 | 03:11 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
low vacuum would be at higher RPM, youre cruising at higher RPM= higher end of a gear, doesnt make sense for it to want to unlock at low vacuum times
hmm..
Old Aug 21, 2004 | 03:20 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, low vaccuum is high demand, as in when accelerating at or near WOT.
Old Aug 23, 2004 | 12:43 AM
BlazerMaro's Avatar
Thanks all, I will try that out when I get home from work tomorrow! :hail:
junior419
Apr 7, 2025 11:35 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
dbrochard
Sep 7, 2015 09:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
