Rear end gear install
Old Aug 22, 2004 | 11:38 AM
FireBoid's Avatar
Car: 1987 Firebird, 1997 Camaro
Engine: 2.8L, 3.8L
Transmission: T5, 4L60E
I'm installing 3.77 gears and a Torsen carrier into a 7.5" 10 bolt. I'm good to go with back lash and patterns, but I'd like advice on how to set carrier preload. I've read that you should add identical shims to both sides. Good with that, but how many. How much pre-load would you recommend?
Bill
Old Aug 22, 2004 | 12:46 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Put it together for your backlash measurements with as much shim as you can get to fit; then for final assembly, add about .010" on each side, and use your case spreader to allow it to go in.
If you don't have a case spreader, you can usually fake it with a couple of large C-clamps on the bearing races.
Old Aug 24, 2004 | 06:06 AM
FireBoid's Avatar
Engine: 2.8L, 3.8L
Thanks RB. That's what I was planning on doing. Just needed confirmation. I've read that "you can't over preload carrier bearings". That article recommended putting in as many preload shims as you can pound in. Sounded like over kill to me.
Bill
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
