Lower Shift Lever Boot
Old Aug 23, 2004 | 08:17 AM
RandogLeader's Avatar
Car: 1989 Camaro RS
Engine: 2.8L V6
Transmission: 5-Speed Manual
Greetings!
I am replacing the clutch in my 89 Camaro RS 2.8L 5-Speed. After removing the console and shift lever I noticed that the boot was torn and was letting dirt and rocks down into the ball joint of the shift lever. This is the boot on the actual lever, not the first boot that comes off with the console, and not the second boot that separates the console from the underside of the car. This boot is on the lever and has a spring clip that allows you to remove it (if it's torn, ha!) But I can't figure out how a new boot would be able to slip over the shaft because it widens towards the bottom. Any help would be appreciated. Thanks!
Ran
Old Nov 4, 2018 | 07:18 PM
JJake's Avatar
Car: 1992 Camaro RS
Axle/Gears: 3.08
Re: Lower Shift Lever Boot
Did you ever figure this out, I have the same problem?
Old Nov 5, 2018 | 11:33 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
IIRC GM # 12542549 will replace it and slip over and fit
Old Nov 5, 2018 | 04:38 PM
JJake's Avatar
Car: 1992 Camaro RS
Axle/Gears: 3.08
Thank you.
F-body driver
Mar 6, 2023 11:44 AM
J-money
Jan 4, 2019 09:45 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
tonys91rs
Sep 2, 2015 07:07 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
