Shift Kit
Car: Camaro
Engine: 305TPI
Shift Kit
I am looking for a shift kit for the 700R4 transmission and i dont know to much about them but i want something where it will chirp in every gear does any company make a shift kit like that?
You only want the shifts to be firm at WOT. The shifts should get firmer with more throttle, and the tires should break loose due to horsepower/torque, and not from how hard you make the transmission shift. Smoother shifting at a light throttle opening, is desirable for long life. The shifts should get firmer with more throttle. I hope this helps.
Car: check
Engine: check
Transmission: check
Originally posted by 92Camaro305
Yes that does help alot thanks but i am still loookin at getting a shift kit what would you recomend
RBob.
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Go to http://pro-built.net/index.cfm?fusea...t&productid=82 this should give you everything you need. Let me know?
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
