trans pan bolt torque
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
hey guys,
my buddy and i changed my trans fluid and filter in my 700-R4 the other day. the rest of the day it ran great, but when i went to get in the car for work i noticed it was leaking trans fluid. we used permatex make a gasket and the cork gasket that came with the purolator filter kit. the permatex was used on the pan side to hold the gasket on the pan so it wouldn't slip off when we put it back on. the bolt torque according to the GM service manual says the bolts should be torqued to 8 foot pounds and he torqued them to 10 because his wrench didn't go down past 10. it's leaking on the back side of the pan facing the back of the car.
if i saw him correctly he did it in the criss cross pattern like on wheel bolts etc...
Might want to just recheck the tq. I just put my gasket on yesterday, and I noticed it had leaked some overnight. I checked the bolt tq, and they were all backed off 1/4 turn. Retorqued them, and no more leaking.
my problem is that neither of my 2 torque wrenches goes down that far (20 lb/ft minimum). is there a way to gauge it by hand?
Car: 89 IROC-Z
Engine: L98 - Stock
Just finished a rebuild last night. According to the Haynes manual, the torque setting for the pan bolts are 26 ft#.
Maybe Trickster could deny/confirm that number in his shop manual. 8 ft# was for the valve body and accumulator bolts.
Adam
Adam
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Okay I went back and checked the servicing section of the Service manual for the 1988 700R4 automatic transmission. The torque value for the transmission oil pan bolts is 15 foot pounds and not 96 inch (8 foot) pounds. I checked with a buddy who does all the transmission work at the local dealership and he confirmed the 15 foot pound setting. So I was off on my original post also, sorry.
update: it seems the torque wasn't a problem it was the crappy gasket that came with the filter. we dropped the pan again and it had huge tears and holes all over and the corners were ripped. we then resealed the pan with permatex copper sealant. not a drop to be seen! crazy gaskets...
Start with all of the bolts just hand tight, then torque to 65 - 75 inch pounds, that is all that is needed. You should see how many transmissions come in with over tightened pan bolts (stripped holes). Make sure that the pan mating surfaces are clean & flat, then use the Duraprene pan gasket with "no" sealer.
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Car: `86 SS / `87 SS
84z96L31vortec
Aug 20, 2017 12:16 AM
maroe624
Apr 16, 2017 08:29 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
