What gears i have?
Old Aug 29, 2004 | 09:37 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Transmission: 5 Speed
What gears i have?
anyone know how to easily check what gears i have or if someone knows what i have. i got a 91 RS 305 TBI. all stock. anyone know what rear-end gears ihave?
Old Aug 29, 2004 | 09:43 PM
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
you need to get the codes out of the center console (if they are still there). the codes off of the RPO (Regular Production Option) sheet will tell you exactly what you have with everything on the whole car, if it is still stock. or you can pull the rear diff cover and count all the teeth. you will know you have found the correct sticker when you see a lot of codes...like GU2...in fact, that is a gear code, for 2.73 gears. put all these codes into the RPO decoder located on the front page and you will learn a lot about your car...
Josh
Old Aug 30, 2004 | 05:39 AM
ede's Avatar
ede
the only 100% sure way to know what you have is to pull the cover and look anything else is just a guess, educated or not.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
